Do-It-Yourself Proto Modules!
A project log for HEXABITZ - Modular Electronics for REAL
A new kind of electronic prototyping!
hexabitzHexabitz • 08/13/2018 at 03:54•0 Comments
Many of you asked about proto board modules to make your own customized, Hexabitz-compatible modules! Well, the wish came true :D We just released our first batch of proto board modules (both TPH and SMT) more designs coming later.
Let us know what cool stuff you'd build with them!
https://hexabitz.com/product-category/modules/
H00R40 - 100-mil TPH Proto Board
H00R40 is a through-hole proto board module with 100-mil plated hole pattern. Use this module to prototype any circuit you want and add it to your Hexabitz collection! The module features a 1-mm plated drill pattern with 100 mil spacing. Six array and six power ports are available to seamlessly integrate with Hexabitz ecosystem. Power ports are separate from each other, in case you need multiple voltage rails in your array.
H00R50 - 100-mil SMT Proto Board
H00R50 is a surface-mount proto board module with 100-mil pad pattern. Use this module to prototype any circuit you want and add it to your Hexabitz collection! The module features a 92-mil-by-92-mil SMT pad pattern with 100 mil spacing. Six array and six power ports are available to seamlessly integrate with Hexabitz ecosystem. Power ports are separate from each other, in case you need multiple voltage rails in your array.
H00R60 - 50-mil SMT Proto Board
H00R60 is a surface-mount proto board module with 50-mil pad pattern. Use this module to prototype any circuit you want and add it to your Hexabitz collection! The module features a 42-mil-by-42-mil SMT pad pattern with 50 mil spacing. Six array and six power ports are available to seamlessly integrate with Hexabitz ecosystem. Power ports are separate from each other, in case you need multiple voltage rails in your array.
