The T-1 project blog is beginning to get a bit unwieldy, so I have decided to document the computer sub-systems as separate projects, and use this one as a 'top level' project to tie everything together.
The ferrite core memory is the first sub-project, it will be followed (eventually) by the ALU, program memory, etc. as I work through and build them.
Yup, it's a good way to go :-)
