The jig to test the flip-flops has been finished:
The jig is basically an Arduino Mega 2560 and a Protoshield. Press the 'GO' button and the flip-flop under test is checked for /RST, /SET, D->Q, and output tristate functionality. I've tested the 18 flip-flops I made earlier and found 4 failures - more than I'd like. But the jig indicates at what point in the testing that the failures fail so troubleshooting shouldn't be too difficult. And I have 14 which are ok!
Andrew Starr
Smart ! :-)
