Happy Birthday, Mr Boole
A project log for ED-64: A discrete 8-bit computer
ED-64 will be an 8-bit computer built with discrete components, and will feature a ferrite core memory (documented as a separate project).
andrew-starrAndrew Starr • 11/03/2015 at 06:05•1 Comment
There has been a hitch in arranging a stencil for the AND gates (thanks for nothing, Paypal) so I have hand-soldered the first one to test the design:
Next up, a jig to test finished AND, OR and NAND gates. I also intend to whip up a carrier board to do some speed and propagation delay tests.
Also, I have repaired the 4 faulty flip-flops from my first batch of 20. The usual problems - diodes around the wrong way, missing resistors.
Yann Guidon / YGDES wrote 11/03/2015 at 08:25 • point
If Boole knew...
