I've populated one of the core planes to experiment with. I've discovered it's quite tough getting that 4th wire threaded, so I will try a 3-wire system i.e. the sense and inhibit circuitry with share the same wire.
The next step is to put together some current drivers and sensing circuitry.
Andrew Starr
3-wire systems tend to be later generation. I've got a pretty good idea how to go about it.
Most core memories I know of have only 3 wires...
Good luck with the electronics !
