My 32bit binary samples are left justified!!!! looking at the binary numbers converted something looks wrong.
if I copy from uint32_t to a uint8_t with a bit shift of >>24 and mask & 0xFF I should get an 8 bit number represetation of the 32bit number.
but i'm getting only 11111111 whatever the 32 bit number. no wonder i'm getting some quite interesting noises on the reciever !
How do you convert a LEFT JUSTIFIED 32 bit number to 8 bit ?
do I need to right justify first ? and then bitwise shift >>24 ?
google brings up a solution to justify binary from right to left but not from left to right !!
