and here is the code for the LM75 on board the trinket shield, which finally works.
March 6, 2014
Spark Fun Electronics
Nathan Seidle
Updates by Joel Bartlett
This code is originally based Dean Reading's Library deanreading@hotmail.com
http://arduino.cc/playground/Main/SevenSegmentLibrary
He didn't have a license on it so I hope he doesn't mind me making it public domain:
This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
This sketch provides a simple counter example for the HP Bubble display from SparkFun.
https://www.sparkfun.com/products/12710
Pinout for HP Bubble Display:
1: Cathode 1
2: Anode E
3: Anode C
4: Cathode 3
5: Anode dp
6: Cathode 4
7: Anode G
8: Anode D
9: Anode F
10: Cathode 2
11: Anode B
12: Anode A
#include <Wire.h>
#include "SevSeg.h"
//Create an instance of the object.
SevSeg myDisplay;
//Create global variables
unsigned long timer;
int deciSecond = 0;
int f;
void setup()
Wire.begin();
Serial.begin(9600);
int displayType = COMMON_CATHODE; //Your display is either common cathode or common anode
//This pinout is for a bubble dispaly
//Declare what pins are connected to the GND pins (cathodes)
int digit1 = 3; //Pin 1
int digit2 = 4; //Pin 10
int digit3 = 5; //Pin 4
int digit4 = 6; //Pin 6
//Declare what pins are connected to the segments (anodes)
int segA = 8; //Pin 12
int segB = 9; //Pin 11
int segC = 10; //Pin 3
int segD = 11; //Pin 8
int segE = 12; //Pin 2
int segF = 13; //Pin 9
int segG = 14; //Pin 7
int segDP= 15; //Pin 5
int numberOfDigits = 4; //Do you have a 1, 2 or 4 digit display?
myDisplay.Begin(displayType, numberOfDigits, digit1, digit2, digit3, digit4, segA, segB, segC, segD, segE, segF, segG, segDP);
myDisplay.SetBrightness(100); //Set the display to 100% brightness level
// timer = millis();
void loop()
char tempString[10]; //Used for sprintf
sprintf(tempString, "%4d", f); //Convert deciSecond into a string that is right adjusted
myDisplay.DisplayString(tempString, 4); //(numberToDisplay, decimal point location in binary number [4 means the third digit])
if (millis() - timer >= 1000)
Wire.write(0x00);
Wire.requestFrom(72, 2);
while(Wire.available())
int8_t msb = Wire.read();
int8_t lsb = Wire.read();
// strip one bit of the lsb
lsb = (lsb & 0x80 ) >> 7; // now lsb = 0 or 1
f = msb * 10 + 5 * lsb;
// add to to form an float
Serial.println(f,1);
timer = millis();
davedarko
