at last i find the QMSDP team algorithm for seizure predicting efficient enough.
I'm going to start using it's Q features part in real device temporary and after a success running the algorithm on electrical device, I'll add other QMSDP parts to it.
you can see whole project here: https://github.com/drewabbot/kaggle-seizure-prediction
i can tell a summary of Q features algorithm as following:
using lasso GLM mechanism on following functions:
-Spectrum at six frequency bands: delta (0.1-4Hz), theta (4-8Hz), alpha (8-12Hz), beta (12-30Hz), low-gamma.
(30-70Hz) and high gamma (70-180Hz).
-Spectral edge power of 50% power up to 40Hz.
-Shannon's entropy at dyadic frequency bands.
-Spectrum correlation across channels at dyadic frequency bands.
-Statistical moments: skewness and kurtosis.
this part uses 1 minute windows and 400hz sampling rate.
it will collapses the scores to a single score by mean function.
