To keep costs down, I bought some cheap micro 9g servos from HobbyKing. They have a torque rating of 1.7kg / cm or something... I figured it would be enough, as long as I kept the weight down.
Well, I was kinda correct. However, I could not use the legs I had originally designed (a simple, yet long, thin 'insect-looking' leg). While only 8 cm long, the servos were unable to keep the body standing properly without making all sorts of bad noises. However, by reducing the legs to be shorter (about 3cm long), I was able to get it working quite well; plus, it was christened with the name of 'Subby'.
(And now, even my two year old will walk up to me and ask if I am working on Stubby... or 'tubby' as he says).
