After a number of very busy days where I was unable to work on Stubby at all, I have finally found enough time to hook up the Bluetooth radio and verify that everything works. So far, I only am emulating the Universal Controller's protocol (which, BTW, works very well; I may actually write up a simple computer-based controller which lets you use a keyboard to control it rather than relying on a separate physical controller).
The proof of concept code is below: simply put, it turns Stubby on (hits the "Start" PS2 button), moves forward for one second, backwards for one second, stops for a second, and then turns Stubby off again.
#!/usr/bin/env python2.6
# Simple POC for computer controlled Stubby movement
import serial, sys
from time import sleep
ser = serial.Serial("/dev/tty.Stubby-DevB", 38400)
ser.write("\x93") #Start (to begin)
#Reset all analog controls (not strictly needed)
ser.write("\x0F") #Left X to neutral
ser.write("\x2F") #Left Y to neutral
ser.write("\x4F") #Right X to neutral
ser.write("\x6F") #Right Y to neutral
sleep(0.01)
#Movement
ser.write("\x20") #Forward
ser.write("\x10") #Left X to neutral
sleep(1)
ser.write("\x3F") #Backward
sleep(1)
#Stop
sleep(1)
ser.write("\x93") #Start (to end)
The Big One
