The initial low level Library is finished, tested, and verified on all 6 supported chips. I wrote a testing program that supports output both via the OLED and USB and exercises the flash chip. I also created my own testing 'rig' that allows me to easily replace the flash chip. I needed to use a level converter IC that is not on the mooltipass to handle the spi bus connection length.
The next steps for the Flash Driver / Structures is to implement the node structure.
mikeneiderhauser
Central Space Alliance
Sanpi
DoctorDre
Victoria
