21Step 21
Once you have the texture matched, you'll paint the wall to match. I made sure to sand the lip where the Touchpad rests smooth, almost to the painters tape underneath since I wanted to Touchpad to fit as it it were on my desk.
22Step 22
Now to add some thin metal strips to the back of the HP Touchpad. I just used some black painted metal plates I had and some 3M Double sided tape. Bend the metal to follow the curve of the Touchpad's back.
23Step 23
Add some double-sided tape, butting edges to keep it smooth/flat.
24Step 24
Stick the metal plate to the back, one plate for landscape and one for portrait, since the Touchstone supports charging in either orientation. Since my plates were already painted, I didn't want to cut them so they fit perfectly. This looked fine for my purposes.
25Step 25
Done and working, I can run HP's WebOS, Android ICS Cyanogenmod, and thanks to the Splashtop App I can remote into my Windows or Mac PCs.
26Step 26
You can choose a background that compliments the wall paint color.
27Step 27
Mac OSX and I added a nice screw-less wall plate to the switches below.
28Step 28
Windows 7
