4 Voices are already done (2 per board), next up i will add another 2 Low Voices and a Power/Mixing Board.
I started with transferring the Schematic into KiCad and also will play around with +/- 12V (Eurorack Standard) instead of 9V and voltage divider as in the original project so it can be converted into a Eurorack Module.
WooDWorkeR
