Hackaday.io Hackaday.io
Sign up Log in
Automatic Frisbee Launcher
Robotic Frisbee Launcher that aims for colored targets
jordan-rjaudJordan Réjaud
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.9k views
2 comments
1.2k followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 2
View Gallery
3.9k
2
1.2k
9
Team (1)
  • jordan-rjaudJordan Réjaud
Join this project's team
completed project
hardware
frisbee launcher disk launcher Robotics cMU carnegie mellon
This project was created on 09/26/2015 and last updated 7 years ago.
Description
Automatic Targeting Frisbee Launcher. This machine uses a camera to automatically aim for the colored target that you selected.
It uses a very powerful DC motor to induce linear and rotational motion of the frisbees and shoot them at the target.
A servo motor ostensibly pushed the little frisbees out of the frisbee containment tower (dirty tin coffee can) and towards the DC motor.
A planetary gear is used to line up the launcher horizontally and a linear actuator lines it up vertically.
Details
Log In/Sign up to comment
Sign up with Github
OR
Jordan Réjaud wrote 09/28/2015 at 17:19 • point
Thanks, it tore off parts of the frisbee in early version haha, we had to done the power down a tad. The spinning disk attached to the motor and the quarter circle ramp which the frisbee goes down are both coated with a black rubber-esque material (to give the frisbee angular velocity), but the material also tore through earlier frisbees.
zakqwy wrote 09/28/2015 at 13:43 • point
awesome! That is a beastly DC motor!
Uma inovação para a ampliação da eficiência do motor Ionico .
Project Owner Contributor
Motor Ionico Vdc parallel magnetic fiel 40 KV
jose-pedro-r-a-ribeiroJose Pedro R. A. Ribeiro
Music on a DC Motor, tone generation through Motor RPM
Musical DC-Motor
treibairtreibair
DIY DCMotor smallest Steppermotor with Driver and Servofunction in one package
XMoto DC as Servomotor
frank-herrmannFrank Herrmann
just disassembling
Japan Servo Co. Brushless motor from inside
manamanamanamana
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Automatic Frisbee Launcher", please tell us the reason.
Send message
Remove Member
