So I gave up on using that formula, and instead tabulated the frequencies -- that's just 8 bytes, after all. I also changed the encoding of the notes, so that it's easier to read (in octal). The 3 least significant bits are the pointer to the table of frequencies, the next two bits are the octave (with 0 being a pause), and the sixth bit is the duration. That got me down to about 800 bytes.
Hmm, but I'm sure I can do better. At this point, I'm basically not using anything from Arduino itself, except maybe for the delay. So what if I just go with plain C, like the good old days? A quick google found me a ready Makefile for the ATtiny85 (complete with fuse flashing), and a bit of looking around got me the _delay_ms() function. Perfect.
The result? See for yourself:
AVR Memory Usage ---------------- Device: attiny85 Program: 492 bytes (6.0% Full) (.text + .data + .bootloader) Data: 8 bytes (1.6% Full) (.data + .bss + .noinit)
If I'm reading this right, that is exactly 500 bytes total. Woo!
The code (with the makefile) is available in the repository here (no rickrolling this time, I promise): https://bitbucket.org/thesheep/nyan/src/495dfa41484dade01bdf7ff79b41f9337f430e5b/main/?at=default
And another 16 bytes by moving the FREQ table into PROGMEM. It seems that the code that copies it into RAM at the beginning is quite large?
haha, 16 bytes is *huge* when you've only got 1kB :)
Yowsah!
And the most important, using plain C and your own routines keeps the power under your control!
Shaved off another 6 bytes by using bitfields instead of explicit masking and shifting.
