ATmega 8 dimmer switch
Small and cheap 12V dimmer with several IOs and communication busses
There will be a programmable 12V dimmer for LEDs with an ATmega8 soon. Just created to use some empty space on a PCB.
Small dimmer for 12V devices like cheap LED strips.
I have created this projekt because thier was some empty space an a 10x10cm pcb. The most importen feature is the support of I2C und UART wich other dimmers with NE55 doesn't have and also the price. The max Power is ca. 50W (conductor = 40mil).
  • 1 × ATmega 8
  • 1 × AMS1117-5.0 LDO 1A
  • 1 × potentiometer 10k 2,54mm
  • 1 × IRFZ44N Discrete Semiconductors / Power Transistors and MOSFETs
  • 1 × capacitors 0603 smd for ATmega 8 and AMS1117-5,0
View all 7 components
  • First Tests
    Ethon11/04/2015 at 13:05 0 comments
    After the pcbs has arrived and after soldering the components i tested the board with a short blink and adc/pwm program.
  • PCBs arrived
    Ethon11/03/2015 at 13:17 1 comment
    After 5 weeks the pcbs arrived and has been cut out. Makerstudio.cc just send 5 pcbs
    and the writings are not so good as expected. In a few days i will have functional board.
View all 2 project logs
