![](https://cdn.hackaday.io/images/7714971520545986126.jpg)
Experimenting with scrap pieces of laser cut materials, using the straight edges to align the cases and putting two pieces next to each other to align the switch stems
![](https://cdn.hackaday.io/images/1682721520546070854.jpg)
Soldering the switches, the solder fumes visible in the picture.
![](https://cdn.hackaday.io/images/5800531520546169448.jpg)
Trying different LED colors. Eventually Blue won.
![](https://cdn.hackaday.io/images/7991521520546242101.jpg)
And the basic concept works. All of the switches have to be ON for the LED to light up. Time to tweet a little teaser picture...
![](https://cdn.hackaday.io/images/4436831520546302002.jpg)
The solder joints for the first four months. Nothing is bridged, but some of the joints could use a little less solder. I see a few Hershey's Kisses in there.
![](https://cdn.hackaday.io/images/6552941520546351515.jpg)
