Hackaday.io Hackaday.io
Sign up Log in
Garter Gun
The best garter toss accessory ever! Shoot the garter with a pneumatic cannon.
john-leemanJohn Leeman
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.2k views
4 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 19
    • View all
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
1.2k
4
0
2
Team (1)
  • john-leemanJohn Leeman
Join this project's team
hardware
ongoing project
wedding pneumatic cannon
This project was created on 10/02/2015 and last updated 11 years ago.
Description
I wanted a unique way to toss the garter at our wedding. I thought about rubber band style guns, but didn't have the time to build one. A pneumatic cannon was a quick, simple, and fun solution! WARNING: This project has the potential to hurt you and others. Do not point the gun at anyone directly. Do not load heavy projectiles. Do not over pressurize the gun or it could fragment sending you and others to the hospital or graveyard. Use with brain engaged.
Components
  • 2 × 3/4" metal pipe nipple
  • 1 × 3/4" Air ball valve
  • 1 × 3' length of 1.5" PVC Pressure Rated
  • 1 × 3' length of 2" PVC Pressure Rated
  • 2 × 2" to 3/4" threaded PVC Bushing Pressure Rated
View all 19 components
Project Logs
Collapse
  • Wedding Success
    John Leeman • 12/01/2015 at 03:00 • 0 comments
    This garter gun was a hit! We had great fun with it at the wedding and even got some video from a drone (which was also our ring bearer) of the garter shot.
  • Test Fire
    John Leeman • 10/02/2015 at 17:43 • 0 comments
    Video of the garter gun test fire!
  • Build photos
    John Leeman • 10/02/2015 at 14:58 • 0 comments
    Here are some build photos to help everyone see how things come together. Use PVC glue, teflon tape, and be careful!
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
Alex Rich wrote 10/02/2015 at 17:52 • point
You may want to consider a sprinkler valve instead of a ball valve for quicker activation, once you're done shooting garters you can get maximum velocity with other projectiles that way.
John Leeman wrote 10/07/2015 at 20:59 • point
Yeah, I think that's the way to go. This was a last-minute design, but it ended up working great at the wedding. I hope to have the drone video of the shoot soon. Do you have a preferred supplier for the sprinkler valves online?
Alex Rich wrote 10/07/2015 at 21:06 • point
Yeah I believe we bought ours from this guy who pulled the crappy little solenoid valve that comes with it and swapped in a squeeze valve that opens much more quickly.  Of course you can do that yourself and it saves a few dollars, but we just paid for the value added service.  http://www.spudtech.com/store/index.php?main_page=product_info&products_id=13
John Leeman wrote 10/07/2015 at 22:11 • point
Thanks! I'll be ordering one probably! :)
I am going to use an AMI S6802P (Motorola 6802 Clone) and make a computer around it.
Project Owner Contributor
Making a homemade 6802 computer for fun.
jeffrey-paullJeffrey Paull
This is a small scale - indoor aquaponics test project.
Automated Aquaponics Setup
trent-wainwrightTrent Wainwright
How NOT to build a mercury maze.
Mercury Maze
franklinsteinFranklinstein
A simple project that throws a ball.
Ball Thrower Bot
mukundan-chariarMukundan Chariar
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Garter Gun", please tell us the reason.
Send message
Remove Member
