Board is working!
A project log for USBreadboardIT
Breadboard-compatible USB PIC16F1455 board
wallaceitWallaceIT • 11/01/2015 at 16:47•3 Comments
Board is working! The classical blinky test past smoothly and now an initial version of the test - and maybe other usages - firmware is ready and uploaded on Github: Link
Jarrett wrote 11/02/2015 at 15:59 • point
Good call
WallaceIT wrote 11/02/2015 at 10:26 • point
Yes, in this particular family (PIC16F1454/5/9) the device recovers the clock from the USB line and the oscillator can thus be avoided. I can confirm that in my application USB just works fine without any external crystal or oscillator.
Unfortunately, it's not the same for PIC18F14K50: it's datasheet in fact states: "Because of timing requirements imposed by the USB specifications, the Primary External Oscillator is required for the USB module".
Jarrett wrote 11/02/2015 at 08:42 • point
USB works fine with internal oscillator?
Most schematics that use it have included one, and that would completely blow either size or price requirements for my project.
I'm doing a similar board with the PIC18F14k50 because they're ~15 cents each, which is great.
