Board programmed and tested
A project log for AT26-Chuck
Adapter for playing Atari 2600 with Wii Nunchuck, with or without the accelerometers
danjovicdanjovic • 11/11/2015 at 02:11•0 Comments
I have finally built the programmer/tester adapter using veroboard. The board was programmed and it is now working.
I think it worth to mention that the pinout was carefully choosen so all the programming signals would be available at the interface connector and thus elimitating the need for an ICSP connector on the board.
