Pictures of the [S]NES alternate configuration assembly
A project log for AT26-Chuck
Adapter for playing Atari 2600 with Wii Nunchuck, with or without the accelerometers
danjovicdanjovic • 07/06/2016 at 01:21•0 Comments
The female connector was taken from a cheap SNES extender. The wire colouring is not equal that from the original controller, so the wires must be identified prior to soldering
The overview of the assembly is show below. 3 of the wires are soldered on the bottom (lower) face, while the others are soldered on the top layer
Below is a close view of the wiring, showing the top face.
The bottom face is shown below. Notice the modification from pin 7 of the micro-controller to the central pad.
