Ok so this time i'm being careful with the glass bed, i found some aluminium tape that i've used to try and improve thermal conduction. The alu tape is a bit thin so it still doesnt conduct the heat great but there is definite improvement. I'll probably stick the brim down to the bed when printing large footprint parts.
The most important part about the alu tape is that it allows the use of an induction sensor.
