Hackaday.io Hackaday.io
Sign up Log in
Uranium Marble Ring Oscillator
danielDaniel
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.6k views
4 comments
13 followers
  • Description
  • Details
  • Files 0
  • Components 7
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 4
View Gallery
1.6k
4
13
14
Team (1)
  • danielDaniel
Join this project's team
  • Youtube
  • Original design
hardware
completed project
uranium marble
This project was created on 10/06/2015 and last updated 11 years ago.
Description
Seven UV LEDs facing inwards on a circle around a uranium glass marble, wired as a ring oscillator to create a beautiful glowing/spinning effect.
This is my take on the original design that has apparently been around since at least 2009 (at 26C3).
Details
Components
  • 1 × Uranium Marble
  • 7 × UV LEDs
  • 7 × 2N7000 transistor Discrete Semiconductors / Diode-Transistor Modules
  • 7 × 300 Ω resistor
  • 7 × 33 kΩ resistor
View all 7 components
Log In/Sign up to comment
Sign up with Github
OR
lantramnamcodon wrote 05/08/2017 at 15:59 • point
have you tried to make laser with uranium glass?However that could have made you cancer.
Rjpope42 wrote 02/15/2016 at 16:02 • point
Thanks for the reply, I got some 385 and some 400nm from digikey, the 400nm were cheaper and work better
Rjpope42 wrote 02/07/2016 at 05:32 • point
Very nice!
What wavelength LEDs did you use?
Daniel wrote 02/15/2016 at 11:06 • point
Sorry, a friend had those LEDs just lying around so I don't have any info on that. You can clearly see them emitting visible light... if that helps. Not sure if the marble reacts to one specific wavelength..
For my final year at college i design and built a SoapBox Racer
Project Owner Contributor
Soapbox Racer
simon-bettsSimon Betts
'Punk' Collar with RGB LEDs, driven by a DigiSpark and a small LiPo Inspired by a similar design by Adafruit.
RGB Punk Collar
david-hopkinsDavid Hopkins
A write up on my design process for an entry into the Linus Tech Tips and SilverStone Headphone Stand Design Contest
Wall Mounted Headphone Stand
taibhse-designsTAIBHSE DESIGNS
A design of a NE555 with passive and active components of the electronics and of easy acquisition is made.
NE555 Clock Design
danielzapatatoledanoDanielZapataToledano
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Uranium Marble Ring Oscillator", please tell us the reason.
Send message
Remove Member
