New Contact Method: Pogos
A project log for PowerBlade
PowerBlade is the smallest, lowest cost, true-power plug-load power meter, and communicates to smartphones over BLE
sam-debruinSam DeBruin • 11/10/2015 at 19:41•0 Comments
Having difficulty with the longevity of the flexible tabs, we have implemented and evaluated a more stable method for making contact with the AC. The method is spring loaded "pogo" pins mounted in the plane of the PCB. These pins make contact with the AC prongs as they pass through (as the flexible tabs do as well) but since these spring loaded pins are designed for multiple insertions they seem to last significantly longer.
