- PlatformIO Home - interact with PlatformIO ecosystem using modern and cross-platform GUI:
- Multiple themes (Dark & Light)
- Ability to specify a name for new project
- Control PIO Unified Debugger and its firmware loading mode using debug_load_mode option
- Added aliases (off, light, strict) for LDF Compatibility Mode
- Search for a library using PIO Library Registry ID
(e.g.pio lib search id:13
) - Show device system information (MCU, Frequency, RAM, Flash, Debugging tools) in a build log
- Show all available upload protocols before firmware uploading in a build log
- Handle "os.mbed.com" URL as a Mercurial (hg) repository
- Improved support for old mbed libraries without manifest
- Fixed project generator for Qt Creator IDE (issue #1303, issue #1323)
- Mark project source and library directories for CLion IDE (issue #1359, issue #1345, issue #897)
- Fixed issue with duplicated "include" records when generating data for IDE (issue #1301)
