- Project Generator: added new targets for CLion IDE "BUILD_VERBOSE" and "MONITOR" (serial port monitor) (issue #359)
- Fixed an issue with slow updating of PlatformIO Core packages on Windows
- Fixed an issue when platformio ci recompiles project if
--keep-build-diroption is passed (issue #2109) - Fixed an issue when
$PROJECT_HASHtemplate was not expanded for the other directory***_diroptions in "platformio.ini" (Project Configuration File) (issue #2170)
Ivan Kravets
