- PIO Unified Debugger: improved debugging in
debug_load_mode = modified
and fixed an issue with useless project rebuilding - Project Generator: fixed a VSCode C/C++'s "Cannot find" warning when CPPPATH folder does not exist
- Fixed an "IndexError: list index out of range" for Arduino sketch preprocessor (issue #2268)
- Fixed an issue when invalid "env_default" in "platformio.ini" (Project Configuration File) results into unhandled errors (issue #2265)
