- Improved code builder for parallel builds (up to 4 times faster than before)
- Generate .travis.yml CI and .gitignore files for embedded projects by default (issue #354)
- Removed prompt with “auto-uploading” from platformio init command and added
--enable-auto-uploading
option (issue #352) - Fixed incorrect behaviour of platformio serialports monitor in pair with PySerial 3.0
