- Added support for the new ESP8266-based boards (SparkFun ESP8266 Thing, NodeMCU 0.9 & 1.0, Olimex MOD-WIFI-ESP8266(-DEV), Adafruit HUZZAH ESP8266, ESPino, SweetPea ESP-210, WeMos D1, WeMos D1 mini) to Espressif development platform
- Created public platformio-pkg-ldscripts repository for LD scripts. Moved common configuration for ESP8266 MCU to
esp8266.flash.common.ld
(issue #379) - Improved documentation for Espressif development platform: OTA update, custom Flash Size, Upload Speed and CPU frequency
- Fixed reset method for Espressif NodeMCU (ESP-12E Module) (issue #380)
- Fixed issue with code builder when build path contains spaces (issue #387)
- Fixed project generator for Eclipse IDE and “duplicate path entries found in project path” (issue #383)
