- Simplified Continuous Integration with AppVeyor (issue #671)
- Automatically add source directory to
CPPPATH
of Build System - Added support for Silicon Labs SLSTK3401A (Pearl Gecko) and MultiTech mDot F411 ARM mbed based boards
- Added support for MightyCore ATmega8535 board (issue #585)
- Added
stlink
as the default uploader for STM32 Discovery boards (issue #665) - Use HTTP mirror for Package Manager in a case with SSL errors (issue #645)
- Improved firmware uploading to Arduino Leonardo/Due based boards
- Fixed bug with
env_default
whenpio run -e
is used - Fixed issue with
src_filter
option for Windows OS (issue #652) - Fixed configuration data for TI LaunchPads based on msp430fr4133 and msp430fr6989 MCUs (issue #676)
- Fixed issue with ARM mbed framework and multiple definition errors on FRDM-KL46Z board (issue #641)
- Fixed issue with ARM mbed framework when abstract class breaks compile for LPC1768 (issue #666)
