PlatformIO IDE 1.4.0
- Added "Local echo" to advanced settings for Serial Port Monitor (#144)
- Improved PlatformIO IDE Installer for Linux Arch and macOS (#146)
PlatformIO CLI 2.11.2
- Improved support for Microchip PIC32 development platform and ChipKIT boards issue #438
- Added support for Pinoccio Scout board issue #52
- Added support for Teensy USB Features (HID, SERIAL_HID, DISK, DISK_SDFLASH, MIDI, etc.) issue #722
- Switched to built-in GCC LwIP library for Espressif development platform
- Added support for local
--echo
for Serial Port Monitor issue #733 - Updated
udev
rules for the new STM32F407DISCOVERY boards issue #731 - Implemented firmware merging with base firmware for Nordic nRF51 development platform issue #500, issue #533
- Fixed Project Generator for ESP8266 and ARM mbed based projects (resolves incorrect linter errors)
- Fixed broken LD Script for Element14 chipKIT Pi board issue #725
- Fixed firmware uploading to Atmel SAMD21-XPRO board using ARM mbed framework issue #732
