PlatformIO IDE 1.6.0
- Library Manager page with advanced explanations how to use it
- Asynchronous C/C++ project index rebuilding (Autocomplete, Linter)
- Added new setting
Show PlatformIO service files
in Tree View that is turned off by default - Added new baud rates (460800 and 921600) to Serial Port Monitor
PlatformIO CLI 3.1.0
- New! Dynamic variables/templates for Project Configuration File "platformio.ini" (issue #705)
- Summary about processed environments (issue #777)
- Implemented LocalCache system for API and improved a work in off-line mode
- Improved Project Generator when custom
--project-option
is passed to platformio init command - Deprecated
lib_force
option, please use lib_deps instead - Return valid exit code from
plaformio test
command - Fixed Project Generator for CLion IDE using Windows OS (issue #785)
- Fixed SSL Server-Name-Indication for Python < 2.7.9 (issue #774)
