- Pre/Post extra scripting for advanced control of PIO Build System (issue #891)
- New lib_archive option to control library archiving and linking behavior (issue #993)
- Add "inc" folder automatically to CPPPATH when "src" is available (works for project and library) (issue #1003)
- Use a root of library when filtering source code using library.json and
srcFilter
field - Added
monitor_*
options to white-list for Project Configuration File "platformio.ini" (issue #982) - Do not ask for board ID when initializing project for desktop platform
- Handle broken PIO Core state and create new one
- Fixed an issue with a custom transport for PIO Unit Testing when multiple tests are present
- Fixed an issue when can not upload firmware to SAM-BA based board (Due)
