Open Source Tool Flow Works!
A project log for CAT Board
The CAT Board is part of a Raspberry Pi-based hand-held FPGA programming system.
dave-vandenboutDave Vandenbout 10/21/2015 at 04:431 Comment
I actually got the open source FPGA tools working on the RPi a few days ago, but I've been remiss in posting to this log.
Ed Vidal provided me with an archive that I could load onto my RPi using the squashfs tools. Unfortunately, they didn't work. It turned out I was running the Raspbian Wheezy distribution and I had to upgrade to Jessie. After doing that, it was easy to compile a simple blinker example. (Ed even prepared the example with the correct pin assignments for the CAT Board. What a guy!) Then it was just a matter of downloading the bitstream to the CAT Board and watching the LEDs turn on and off. Check out the video below for all the excitement!
With the RPi-host FPGA tools in place, example designs can now be compiled to test the SDRAM and I/O ports.
Rich text editor
Xark wrote 10/21/2015 at 05:06 point
Achievement unlocked! :-)  Seems to work nicely.  I am curious, was this using a Raspberry Pi 1 or 2?
