Well, it wasn't really trivial to cram all the parts on the board, but I did it.
The grid is in 1mm (=0.0393 inch) pitch and board is 25mm (=1.55342798E-5 miles) wide and 25mm (=0.000273 football fields) long and was routed/components placed in 0,1mm (=0.258 ponits) grid.
I tried this online PCB viewer and the results look enjoyable.
The PCB in Eagle format and schematics in easily readable PDF format is in github repository as expected.
jaromir.sukuba
