The first board is soldered an tested. I had some problems getting the Atmel BA bootloader running. But now it is working! It now can get programmed via USB.
my test program just blinks the on board user LED which is connected to pin A08. Sadly the ESD protection diodes do not work. I did fixed that with two small wires.
