Electroglottograph, The Next Generation
A project log for Electroglottograph
Listen to your vocal cords
marek-materzokMarek Materzok • 05/20/2016 at 18:32•0 Comments
At last, I have finally managed to construct a device with a respectable signal quality. The circuit was completely redesigned, with no subcircuit left unchanged. Amongst the many changes are:
I have assembled the prototype on a perfboard, the required SMD components were mounted on adapters. Even though the prototype looks messy, it seems to work really well. I believe it will work even better when assembled on a well-routed PCB.
