The stand was 1/2" too low, but as suspected, it was real hard to adjust. Ended up just living with it being too low. There's either drilling new holes or putting wood spacers on top of the springs, which of course, would change the spring behavior. Pedaling is real hard, when standing. Even damper pedaling alone is not as precise. You have to practice more with pedal.
