Progress so far:
- Arranged production of PDP-11 switches. Currently waiting for a revision to the CAD model of the switches, then it's a go.
- Schematics are done, as is the first draft of the PCB layout. The only thing left is to verify exact component placement by measurements on an original 11/70 in December
- Decided to produce the front panel bezel using vacuforming. First draft of CAD model, for the mold, is done but it needs more exact measurements to wrap up.
