EasyIoT Cloud
Build your IoT in couple of minutes
We want to build Easy Internet of Things framework. With EasyIoT Cloud framework you are able to build your most simple IoT in couple of minutes.
Our goal is to create secure, reliable and cheap platform for Internet of Things. We will provide DIY tutorials to build IoT using components like Arduino, NRF24L01+ and ESP8266. With help of EasyIoT community we will make IoT world Easy Internet of Things world (EasyIoT) .
EasyIoT framework is not home automation. Of course you can build home automation system, but you can build much more. Do you need advanced alarm system, remote plant irrigation system, solar cell charger control, SMS controlled heater, door opener, hydroponic system or even automation process control system. All this you can easily build with EasyIoT framework.
  • 1 × ESP8266
  • 1 × sensor modules
View all 11 project logs
EasyIoT wrote 10/15/2015 at 11:29 • point
Right now it supports only http communication (not secure), but we will add secure SSL communication for sensors and WEB interface. If you remember gmail or facebook at beginning they did not support SSL communicatin. Now it's testing phase...
M.R. Inc wrote 10/15/2015 at 11:22 • point
Wheres the security in this system?
