Data Acquisition Box
A data acquisition box that is able to capture and graph data from analogue and digital sensors using a Raspberry Pi
Using a Raspberry Pi and a MCP3008 (8-Channel 10-Bit ADC With SPI Interface), I wanted to be able to pull in data from analogue sensors and digital sensors and record the data and/or graph it in real time. Using the Pi, the chip, and some test sensors I am writing some python code to capture the data and display it on the Pi.
Kel Bunyan wrote 12/09/2017 at 07:54 • point
Hello Kevin , How did you go with Data Acquisition box i am looking for something like this for recording sensor data for intermittent problem in farm equipment.If we can see the voltage at numerous points with a timestamp the operator can say at 1051 am the machine faulted and would not drive.
