Faster, but still pretty slow
A project log for FPGA-based GPU as high speed learning platform
FPGA-based GPU and sprite engine with burst optimized design, implemented across several FPGA platforms and memory systems.
ian-hanschenIan Hanschen • 11/05/2015 at 04:36•0 Comments
Messed around with bus priority on the SRAM and SDRAM, tweaked the JTAG command batch and sleep time.
Need to stick some FIFOs on the memory ports.
