Motors are generally segmented by how they are actuated. A brushed motor is physically different from a stepper and thus is actuated differently. The difference, however, is actually how the actuation is initiated & controlled. But there is far more that differentiates motors and the differences matter when choosing the appropriate motor for an application:
- Physical dimensions of body & shaft
- Weight
- Mounting options
- Shaft shape
- Shaft options like double ended, extended & threaded
- Output attachments like gears, pulleys & vibrating weights
- Cost
- Availability, sourceability
- Operating Voltage (max, starting)
- Speed (no load/loaded), Current (no load/loaded/stall), Torque (starting/stalled)
- Sometimes datasheets will include a load to give you a better real-world estimate
- Operating temp
- Output modifier like gears and the gearing scheme (spur, planetary)
- Non-standard output layouts, like right-angle. These are my favorite and I've never had a use for them.
- Sensing option for closed-loop systems (encoders, pots)
- Built-in controllers if you wanna get all fancy
- Motor type-specific attributes like number of coils or magnet type
- Robustness (better term?) like bearing type, gearing material & type of encoder
That's a lot of differences to consider! Am I missing any?
