Main focus on this project was size, but after the first run of PCBs came back, I noticed that I could make it much much smaller. Also the USB PCB connector fits nicely into the USB Port of a MacBook Pro but is quite loose in some other sockets.
A project log for Pomodorino
Pomodoro is a time management technique where you spilt your task into smaller ~20 Minute sections. This device helps you to keep focused
