Use of buttons
A project log for Key Pass
Keychain USB multiple password manager/generator/injector
danjovicdanjovic • 10/27/2015 at 03:38•3 Comments
I've been considering about removing both buttons and using [NUM LOCK] and [SCROLL LOCK] for changing the slot and sending the password, respectively. In this case a hidden reset button would place the microcontroller in bootloader mode.
On the other hand, without buttons I would not be able to use the Key Pass in devices without keyboard, like tablets and phones.
Maybe the best solution for now is to allow the change of slot by either pressing [select] button or [Num lock] on the keyboard, and sending (typing) the password either by [send] button or by [Scroll Lock] key.
danjovic wrote 10/28/2015 at 00:41 • point
Well, I was planning only the large USB version, used with an adapter cable (like USB OTG). The small USB plug might me tricky to find, and I think it is a bit fragile.
I've been also wondering about using only one button, where a short press could select the slot and a long press could type the password.
Mike Maluk wrote 10/28/2015 at 00:45 • point
Ah, that's a great point. I do like the press length selection variation!
Mike Maluk wrote 10/28/2015 at 00:28 • point
If you're planning on using it for tablets and phones, would you make a version with a micro connector? If so, it'd be neat to have that with buttons, and the larger USB version button-less.
