redefine wikit features
A project log for Wikit: programmable hardware with flowchart
Making Hardware with Simple Drag and Drop
minqi-baominqi bao • 11/18/2015 at 02:24•0 Comments
We just redefine some of the wikit features based on makers feedback.
It would be more helpful in this way. Do let us know if we miss anything which you wanted most
With wikit, you can make real complex hardware projects without any technical barrier!
1. Arduino code import to visual flowchart block makes you using arduino resources without coding knowledge
2. Detail hardware connection guidance with self-testing function help you get rid of any hardware trouble before programming
3. More than 100 build-in flowchart hardware module driver blocks give you a quick start
4. build-in elementary access flowchart blocks allow you to D.I.Y your own function
5. Unique compiling algorithm provides you a chance to export design ready code to some specific MCU platforms for production
