wikit app 1.3.3 released while 1.3.4 is under internal testing
major feature update
1) more Ui improve
2)add support for aruidno101 with the following firmware code
3) add support for 0 wire aruidno101 kit
#include <DHT.h>
Example sketch using the Intel CurieIMU library and the General Vision CurieNeurons library
for Intel(R) Curie(TM) devices
Motion is converted into a simple feature vector as follows:
[ax'1, ay'1, az'1, gx'1,gy'1, gz'1, ax'2, ay'2, az'2, gx'2, gy'2, gz'2, ...] over a number of time samples
Note that the values a' and g' are normalized and expand between the running min and max of the a and g signals.
After calibration is made,
Use the serial monitor to edit the category of a motion,
(ex= 1 for vertical, 2 for horizontal, 0 for stillness or anything else),
Start moving the Curie in an expected direction,
and when you press Enter the last feature vector is learned.
Note that this "snapshot" approach is simplistic and you may have to teach several times
a given motion so the neurons store models with different amplitudes, acceleration, etc.
Ideally we want to learn consecutives vectors for a few seconds.
/*firmware version 1.1.6*/
/*enable RGB function/pwm vibration/temperature*/
#include "CurieIMU.h"
#include <CurieBLE.h>
#include <CurieNeurons.h>
#include <Adafruit_NeoPixel.h>
//RGB
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1
#define PIN 5
#define DHTPIN 3 // what digital pin we're connected to
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS 1
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 50; // delay for half a second
const int ledPin = 13; // set ledPin to use on-board LED
const int ledPin_wikit = 14; // set ledPin to use on-board LED
int neuron_count = 0;
//WIKIT FUSIONWIRE NETWORK
#define MP6050_DATA_TYPE 0x80
#define LIGHT_DATA_TYPE 0x84
//WIKIT bit position
#define WIKIT_HEADER 0x0
#define WIKIT_LIGHT 0x5
#define WIKIT_MOTION_NEURON 0x8 // the bit used in apps
#define NEURON_MOTION_LEARNING_MODE_1 0x0A
#define NEURON_MOTION_LEARNING_MODE_2 0x0B
#define NEURON_MOTION_LEARNING_MODE_3 0x0C
#define NEURON_MOTION_LEARNING_MODE_4 0x0D
#define NEURON_MOTION_LEARNING_MODE_5 0x0E
#define NEURON_MOTION_LEARNING_MODE_6 0x0F
#define NEURON_MOTION_CATAGORY_MODE 0x10
#define NEURON_MOTION_DELETE 0x3F
volatile bool WIKIT_MP6050_UPDATED = false;
volatile bool NO_FUSIONWIRE_MP6050 = true;
volatile bool WIKIT_LIGHT_UPDATED = false;
volatile bool WIKIT_LIGHT_REQUIRED = false;
volatile bool WIKIT_LED_ON_REQUIRED = false;
volatile bool WIKIT_LED_OFF_REQUIRED = false;
volatile bool WIKIT_RGB_R_REQUIRED = false;
volatile bool WIKIT_RGB_G_REQUIRED = false;
volatile bool WIKIT_RGB_B_REQUIRED = false;
volatile bool WIKIT_MOTION_NEURON_CAT_REQUIRED = false;
volatile bool WIKIT_MOTION_NEURON_SEND_CAT_REQUIRED = false;
volatile bool WIKIT_MOTION_NEURON_MODE1_LEARN_REQUIRED = false;
volatile bool WIKIT_MOTION_NEURON_MODE2_LEARN_REQUIRED = false;
volatile bool WIKIT_MOTION_NEURON_MODE3_LEARN_REQUIRED = false;
volatile bool WIKIT_MOTION_NEURON_MODE4_LEARN_REQUIRED = false;
volatile bool WIKIT_MOTION_NEURON_MODE5_LEARN_REQUIRED = false;
volatile bool WIKIT_MOTION_NEURON_MODE6_LEARN_REQUIRED = false;
volatile bool WIKIT_MODE1_LEARNING_FINISHED = false;
volatile bool WIKIT_MODE2_LEARNING_FINISHED = false;
volatile bool WIKIT_MODE3_LEARNING_FINISHED = false;
volatile bool WIKIT_MODE4_LEARNING_FINISHED = false;
volatile bool WIKIT_MODE5_LEARNING_FINISHED = false;
volatile bool WIKIT_MODE6_LEARNING_FINISHED = false;
volatile bool WIKIT_LEARNING_FINISHED = false;
volatile bool WIKIT_NEURON_RESTARTED = false;
unsigned char wikit_light;
unsigned char wikit_send_value[9];
unsigned char wikit_latest_recognize;
////BLE
BLEPeripheral blePeripheral; // create peripheral instance
BLEService wikitService("00001523-1212-EFDE-1523-785FEABCD123"); // create service
BLECharacteristic wikitDataChar("00001526-1212-EFDE-1523-785FEABCD123", BLEWrite | BLERead | BLENotify,16);
BLECharacteristic wikitLedSettingChar("00001528-1212-EFDE-1523-785FEABCD123", BLERead | BLEWrite | BLENotify,16);
BLECharacteristic wikitMultilinkPeripheralChar("00001531-1212-EFDE-1523-785FEABCD123", BLERead | BLEWrite | BLENotify,16);
//NEURON
int ax, ay, az; // accelerometer values
int gx, gy, gz; // gyrometer values
int calibrateOffsets = 1; // int to determine whether calibration takes place or not
CurieNeurons hNN;
int catL=0; // category to learn
int prevcat=0; // previously recognized category
int dist, cat, nid, nsr, ncount; // response from the neurons
// Variables used for the calculation of the feature vector
#define sampleNbr 10 // number of samples to assemble a vector
#define signalNbr 6 // ax,ay,az,gx,gy,gz
int raw_vector[sampleNbr*signalNbr]; // vector accumulating the raw sensor data
byte vector[sampleNbr*signalNbr]; // vector holding the pattern to learn or recognize
int mina=0xFFFF, maxa=0, ming=0xFFFF, maxg=0, da, dg;
void setup()
//MQBAO Serial.begin(9600); // initialize Serial communication
// initialize device
pixels.begin(); // This initializes the NeoPixel library.
//MQBAO Serial.println("Initializing IMU device...");
CurieIMU.begin();
// mqbao calibration happens in sensors automatically. indicated by LED on wikit zero wire
// use the code below to calibrate accel/gyro offset values
if (calibrateOffsets == 1)
//MQBAO Serial.println("About to calibrate. Make sure your board is stable and upright");
delay(5000);
//MQBAO Serial.print("Starting Gyroscope calibration and enabling offset compensation...");
CurieIMU.autoCalibrateGyroOffset();
//MQBAO Serial.println(" Done");
//MQBAO Serial.print("Starting Acceleration calibration and enabling offset compensation...");
CurieIMU.autoCalibrateAccelerometerOffset(X_AXIS, 0);
CurieIMU.autoCalibrateAccelerometerOffset(Y_AXIS, 0);
CurieIMU.autoCalibrateAccelerometerOffset(Z_AXIS, 1);
// Initialize the neurons and set a conservative Max Influence Field
hNN.Init();
hNN.Forget(1000); //set a conservative Max Influence Field prior to learning
//int value=hNN.MAXIF(); // read the MAXIF back to verify proper SPI communication
//Serial.print("\nMaxif register=");Serial.print(value);
//while (!Serial); // wait for the serial port to open
// set the local name peripheral advertises
//BLE_START
blePeripheral.setLocalName("CurieNeuron");
blePeripheral.setDeviceName("CurieNeuron");
// set the UUID for the service this peripheral advertises
blePeripheral.setAdvertisedServiceUuid(wikitService.uuid());
//blePeripheral.setAdvertisedServiceUuid("0901");
// add service and characteristic
blePeripheral.addAttribute(wikitService);
blePeripheral.addAttribute(wikitDataChar);
blePeripheral.addAttribute(wikitLedSettingChar);
blePeripheral.addAttribute(wikitMultilinkPeripheralChar);
// assign event handlers for connected, disconnected to peripheral
blePeripheral.setEventHandler(BLEConnected, blePeripheralConnectHandler);
blePeripheral.setEventHandler(BLEDisconnected, blePeripheralDisconnectHandler);
// assign event handlers for characteristic
wikitDataChar.setEventHandler(BLEWritten, wikitDataCharacteristicWritten);
wikitLedSettingChar.setEventHandler(BLEWritten,wikitLedSettingCharcteristicWritten);
wikitMultilinkPeripheralChar.setEventHandler(BLEWritten,wikitMultilinkPeripheralCharcteristicWritten);
//BLE END
// advertise the service
digitalWrite(ledPin,LOW);
digitalWrite(ledPin_wikit,LOW);
blePeripheral.begin();
//MQBAO Serial.println(("Bluetooth device active, waiting for connections..."));
void loop()
blePeripheral.poll();
//delay(10);
// Learn if push button depressed and report if a new neuron is committed
//if (WIKIT_LIGHT_REQUIRED){
//while (!WIKIT_LIGHT_UPDATED){};
if(WIKIT_LIGHT_UPDATED){
wikit_send_value[WIKIT_HEADER] = 0x55;
//wikit_send_value[5] = 0x55;
wikit_send_value[WIKIT_LIGHT] = wikit_light;
//wikit_send_value[3] = 0x22;
wikitDataChar.setValue(wikit_send_value,sizeof(wikit_send_value));
//Serial.print("\nLight data sended");
if (WIKIT_LED_ON_REQUIRED){
digitalWrite(ledPin_wikit,HIGH);
if (WIKIT_LED_OFF_REQUIRED){
if (WIKIT_RGB_G_REQUIRED){
pixels.setPixelColor(0, pixels.Color(0,30,0)); // Moderately bright green color.
pixels.show(); // This sends the updated pixel color to the hardware.
delay(delayval);
if (WIKIT_RGB_R_REQUIRED){
pixels.setPixelColor(0, pixels.Color(30,0,0)); // Moderately bright green color.
delay(delayval);
if (WIKIT_RGB_B_REQUIRED){
pixels.setPixelColor(0, pixels.Color(0,0,30)); // Moderately bright green color.
delay(delayval);
if (WIKIT_MOTION_NEURON_SEND_CAT_REQUIRED){
wikit_send_value[WIKIT_MOTION_NEURON] = wikit_latest_recognize; //means ERROR
delay(51);
/////NEURON LEARNING/CATOGRORIZING DEFAULT IS OFF
if (!WIKIT_MOTION_NEURON_CAT_REQUIRED)
if (!WIKIT_MODE1_LEARNING_FINISHED || !WIKIT_MODE2_LEARNING_FINISHED || !WIKIT_MODE3_LEARNING_FINISHED || !WIKIT_MODE4_LEARNING_FINISHED || !WIKIT_MODE5_LEARNING_FINISHED || !WIKIT_MODE6_LEARNING_FINISHED){
if (WIKIT_MOTION_NEURON_MODE1_LEARN_REQUIRED)
//MQBAO Serial.print("\nLearning motion category mode1"); //Serial.print(catL);
// learn 5 consecutive sample vectors
for (int j=0; j<2; j++){
for (int i=0; i<5; i++)
getVector(false); // the vector array is a global
//Serial.print("\nVector = ");
//for (int i=0; i<signalNbr*sampleNbr; i++) {Serial.print(vector[i]);Serial.print("\t");}
ncount=hNN.Learn(vector, sampleNbr*signalNbr, 1);
wikit_send_value[WIKIT_MOTION_NEURON] = ((neuron_count+1)*9); //means success
neuron_count++;
//MQBAO Serial.print("\tNeurons="); Serial.print(ncount);
//mqbao FIXME need to send back data here
wikit_send_value[WIKIT_MOTION_NEURON] = 100; //means success
WIKIT_MODE1_LEARNING_FINISHED = true;
neuron_count = 0;
else if (WIKIT_MOTION_NEURON_MODE2_LEARN_REQUIRED)
ncount=hNN.Learn(vector, sampleNbr*signalNbr, 2);
neuron_count++;
WIKIT_MODE2_LEARNING_FINISHED = true;
neuron_count = 0;
else if (WIKIT_MOTION_NEURON_MODE3_LEARN_REQUIRED)
ncount=hNN.Learn(vector, sampleNbr*signalNbr, 3);
neuron_count++;
WIKIT_MODE3_LEARNING_FINISHED = true;
neuron_count = 0;
else if (WIKIT_MOTION_NEURON_MODE4_LEARN_REQUIRED)
ncount=hNN.Learn(vector, sampleNbr*signalNbr, 4);
neuron_count++;
WIKIT_MODE4_LEARNING_FINISHED = true;
neuron_count = 0;
else if (WIKIT_MOTION_NEURON_MODE5_LEARN_REQUIRED)
ncount=hNN.Learn(vector, sampleNbr*signalNbr, 5);
neuron_count++;
WIKIT_MODE5_LEARNING_FINISHED = true;
neuron_count = 0;
else if (WIKIT_MOTION_NEURON_MODE6_LEARN_REQUIRED)
ncount=hNN.Learn(vector, sampleNbr*signalNbr, 6);
neuron_count++;
WIKIT_MODE6_LEARNING_FINISHED = true;
neuron_count = 0;
WIKIT_LEARNING_FINISHED = WIKIT_MODE1_LEARNING_FINISHED & WIKIT_MODE2_LEARNING_FINISHED & WIKIT_MODE3_LEARNING_FINISHED & WIKIT_MODE4_LEARNING_FINISHED & WIKIT_MODE5_LEARNING_FINISHED & WIKIT_MODE6_LEARNING_FINISHED; //mqbao 2016.09.04 dummy code
else //NEURON CATOGROTY
if (WIKIT_MOTION_NEURON_CAT_REQUIRED){
// Recognize
hNN.Classify(vector, sampleNbr*signalNbr,&dist, &cat, &nid);
// if (cat!=prevcat)
if (cat!=0x7FFF)
//Serial.print("\nMotion category #"); Serial.print(cat);
if (NO_FUSIONWIRE_MP6050){
//delay(1000);
//for (int i = 0; i < 10; i ++){
wikit_send_value[WIKIT_MOTION_NEURON] = cat; //means success
wikit_latest_recognize = cat;
else
//Serial.print("\nMotion unknown");
//delay(1000);
// for (int i = 0; i < 10; i ++){
wikit_send_value[WIKIT_MOTION_NEURON] = 33; //means ERROR
wikit_latest_recognize = 33;
prevcat=cat;
void getVector(bool mode)
// the reset of the min and max values is optional depending if you want to
// use a running min and max from the launch of the script or not
for (int sampleId=0; sampleId<sampleNbr; sampleId++)
//Build the vector over sampleNbr and broadcast to the neurons
CurieIMU.readMotionSensor(ax, ay, az, gx, gy, gz);
}else{
if (mode){
while(WIKIT_MP6050_UPDATED == false);
//Serial.print("\n mqbao get mp6050 data success");
WIKIT_MP6050_UPDATED = false; // waiting for another update
}else{
delay(1);
// update the running min/max for the a signals
if (ax>maxa) maxa=ax; else if (ax<mina) mina=ax;
if (ay>maxa) maxa=ay; else if (ay<mina) mina=ay;
if (az>maxa) maxa=az; else if (az<mina) mina=az;
da= maxa-mina;
// update the running min/max for the g signals
if (gx>maxg) maxg=gx; else if (gx<ming) ming=gx;
if (gy>maxg) maxg=gy; else if (gy<ming) ming=gy;
if (gz>maxg) maxg=gz; else if (gz<ming) ming=gz;
dg= maxg-ming;
// accumulate the sensor data
raw_vector[sampleId*signalNbr]= ax;
raw_vector[(sampleId*signalNbr)+1]= ay;
raw_vector[(sampleId*signalNbr)+2]= az;
raw_vector[(sampleId*signalNbr)+3]= gx;
raw_vector[(sampleId*signalNbr)+4]= gy;
raw_vector[(sampleId*signalNbr)+5]= gz;
//delay(10);
// normalize vector
for(int sampleId=0; sampleId < sampleNbr; sampleId++)
for(int i=0; i<3; i++)
vector[sampleId*signalNbr+i] = (((raw_vector[sampleId*signalNbr+i] - mina) * 255)/da) & 0x00FF;
vector[sampleId*signalNbr+3+i] = (((raw_vector[sampleId*signalNbr+3+i] - ming) * 255)/dg) & 0x00FF;
void blePeripheralConnectHandler(BLECentral& central) {
// central connected event handler
//MQBAO Serial.print("Connected event, central: ");
//MQBAO Serial.println(central.address());
void blePeripheralDisconnectHandler(BLECentral& central) {
// central disconnected event handler
//MQBAO Serial.print("Disconnected event, central: ");
void wikitDataCharacteristicWritten(BLECentral& central, BLECharacteristic& characteristic) {
// central wrote new value to characteristic, update LED
//MQBAO Serial.print("\nDataCharacteristic event, written: ");
//digitalWrite(ledPin,HIGH);
//MQBAO Serial.print(wikitDataChar.value()[0]);
if (wikitDataChar.value()[0] == NEURON_MOTION_LEARNING_MODE_1){
WIKIT_MOTION_NEURON_MODE1_LEARN_REQUIRED = true;
WIKIT_MOTION_NEURON_SEND_CAT_REQUIRED = false; //mqbao 20160904 added
WIKIT_MODE1_LEARNING_FINISHED = false; //mqbao 20160904 added
}else if (wikitDataChar.value()[0] == NEURON_MOTION_LEARNING_MODE_2){
WIKIT_MOTION_NEURON_MODE2_LEARN_REQUIRED = true;
WIKIT_MODE2_LEARNING_FINISHED = false; //mqbao 20160904 added
}else if (wikitDataChar.value()[0] == NEURON_MOTION_LEARNING_MODE_3){
WIKIT_MOTION_NEURON_MODE3_LEARN_REQUIRED = true;
WIKIT_MODE3_LEARNING_FINISHED = false; //mqbao 20160904 added
}else if (wikitDataChar.value()[0] == NEURON_MOTION_LEARNING_MODE_4){
WIKIT_MOTION_NEURON_MODE4_LEARN_REQUIRED = true;
WIKIT_MODE4_LEARNING_FINISHED = false; //mqbao 20160904 added
}else if (wikitDataChar.value()[0] == NEURON_MOTION_LEARNING_MODE_5){
WIKIT_MOTION_NEURON_MODE5_LEARN_REQUIRED = true;
WIKIT_MODE5_LEARNING_FINISHED = false; //mqbao 20160904 added
}else if (wikitDataChar.value()[0] == NEURON_MOTION_LEARNING_MODE_6){
WIKIT_MOTION_NEURON_MODE6_LEARN_REQUIRED = true;
WIKIT_MODE6_LEARNING_FINISHED = false; //mqbao 20160904 added
}else if (wikitDataChar.value()[0] == NEURON_MOTION_CATAGORY_MODE){
WIKIT_MOTION_NEURON_CAT_REQUIRED = true;
WIKIT_MOTION_NEURON_SEND_CAT_REQUIRED = true; //mqbao 20160904 added
WIKIT_MOTION_NEURON_MODE1_LEARN_REQUIRED = false; //mqbao 20160904 cleaning all learning status here
WIKIT_MOTION_NEURON_MODE2_LEARN_REQUIRED = false; //mqbao 20160904 cleaning all learning status here
WIKIT_MOTION_NEURON_MODE3_LEARN_REQUIRED = false; //mqbao 20160904 cleaning all learning status here
WIKIT_MOTION_NEURON_MODE4_LEARN_REQUIRED = false; //mqbao 20160904 cleaning all learning status here
WIKIT_MOTION_NEURON_MODE5_LEARN_REQUIRED = false; //mqbao 20160904 cleaning all learning status here
WIKIT_MOTION_NEURON_MODE6_LEARN_REQUIRED = false; //mqbao 20160904 cleaning all learning status here
}else if (wikitDataChar.value()[0] == NEURON_MOTION_DELETE){
WIKIT_NEURON_RESTARTED = true;
WIKIT_MOTION_NEURON_SEND_CAT_REQUIRED = false; //mqbao 0721 added
//MQBAO Serial.println("mqbao delete");
WIKIT_MODE2_LEARNING_FINISHED = false; //otherwise the case will hang up --- 2016.9.4 try to open
WIKIT_MODE3_LEARNING_FINISHED = false; //otherwise the case will hang up --- 2016.9.4 try to open
WIKIT_MODE4_LEARNING_FINISHED = false; //otherwise the case will hang up --- 2016.9.4 try to open
WIKIT_MODE5_LEARNING_FINISHED = false; //otherwise the case will hang up --- 2016.9.4 try to open
WIKIT_MODE6_LEARNING_FINISHED = false; //otherwise the case will hang up --- 2016.9.4 try to open
neuron_count = 0;
} else if (wikitDataChar.value()[0] == 0x03){
WIKIT_LIGHT_REQUIRED = true;
} else if (wikitDataChar.value()[0] == 0x38){
void wikitLedSettingCharcteristicWritten(BLECentral& central, BLECharacteristic& characteristic) {
Serial.print("\nled setting characteristics event, written: ");
if (wikitLedSettingChar.value()[0] == 1){
WIKIT_LED_ON_REQUIRED = true;
//MQBAO Serial.print("mqbao led data on\n");
else if (wikitLedSettingChar.value()[0] == 2){
WIKIT_LED_OFF_REQUIRED = true;
} else if (wikitLedSettingChar.value()[0] == 0x17){
WIKIT_RGB_G_REQUIRED = true;
}else if (wikitLedSettingChar.value()[0] == 6){
WIKIT_RGB_R_REQUIRED = true;
}else if (wikitLedSettingChar.value()[0] == 8){
WIKIT_RGB_B_REQUIRED = true;
}else if (wikitLedSettingChar.value()[0] == 0x3b){
void wikitMultilinkPeripheralCharcteristicWritten(BLECentral& central, BLECharacteristic& characteristic) {
//Serial.println(wikitMultilinkPeripheralChar.value()[0]);
Serial.print("wikitMultilinkPeripheralCharcteristicWritten event, written: ");
Serial.println(wikitMultilinkPeripheralChar.value()[1]);
Serial.println(wikitMultilinkPeripheralChar.value()[2]);
Serial.println(wikitMultilinkPeripheralChar.value()[3]);
Serial.println(wikitMultilinkPeripheralChar.value()[4]);
Serial.println(wikitMultilinkPeripheralChar.value()[5]);
Serial.println(wikitMultilinkPeripheralChar.value()[6]);
Serial.println(wikitMultilinkPeripheralChar.value()[7]);
if (wikitMultilinkPeripheralChar.value()[1] == MP6050_DATA_TYPE){//MP6050
NO_FUSIONWIRE_MP6050 = false;
ax = (wikitMultilinkPeripheralChar.value()[3] << 8) | wikitMultilinkPeripheralChar.value()[4];
ay = (wikitMultilinkPeripheralChar.value()[5] << 8) | wikitMultilinkPeripheralChar.value()[6];
az = (wikitMultilinkPeripheralChar.value()[7] << 8) | wikitMultilinkPeripheralChar.value()[8];
gx = (wikitMultilinkPeripheralChar.value()[9] << 8) | wikitMultilinkPeripheralChar.value()[10];
gy = (wikitMultilinkPeripheralChar.value()[11] << 8) | wikitMultilinkPeripheralChar.value()[12];
gz = (wikitMultilinkPeripheralChar.value()[13] << 8) | wikitMultilinkPeripheralChar.value()[14];
//Serial.println(ax);
Serial.println(ax);
Serial.println(ay);
Serial.println(az);
Serial.println(gx);
Serial.println(gy);
Serial.println(gz);
WIKIT_MP6050_UPDATED = true;
}else if (wikitMultilinkPeripheralChar.value()[1] == LIGHT_DATA_TYPE) {//LIGHT
wikit_light = wikitMultilinkPeripheralChar.value()[3];
WIKIT_LIGHT_UPDATED = true;
minqi bao
