All I did here was connect RCA jacks to the amps on the board that connects to the neck of the CRT. Composite video goes to the composite video input for sync. That's about it!
If you do this yourself, just be aware that touching something in there that you shouldn't could give you a pretty good shock, or potentially kill you. So there. You have been warned.
Bentendo64
Patrick LeBoutillier
slandon110
Bruce Land
Just wanted to post instructions for discharging the CRT as it is best to play it safe and discharge the tube before pulling off the neck board and/or doing any work inside a CRT TV (the link is for a monitor, same rules apply to a TV).
http://www.wikihow.com/Discharge-a-CRT-Monitor
