This project runs Arduino based code to upload data every 20s to Thingspeak.
The final assembled system is now complete and available on Tindie.
IoT ESP8266 (NodeMCU) Shield for Real Power Measurements
This basic version is for apparent power only. To keep component count low and the circuit as simple as possible the ADS1115 is used in differential mode eliminating the need for bias resistors. The hard part is getting a licensed electrician to wire up the clamp on current sensor to the main wire coming into the premises. Since we have only 1 channel we are going to monitor overall power rather than power per circuit. Follow the Fritzing diagram below to wire up the prototype on a breadboard. Powering the NodeMCU near the switchboard might be an issue as well, so I installed a DIN rail power socket, this will come in handy for real power measurement later on.
I chose to use the Arduino IDE to program the NodeMCU due to the easy availability of relevant libraries and my personal familiarity with the platform. You can get started quite easily using the latest incarnation of the Arduino IDE and the instructions here. The code running on it for basic apparent power is available here.
This is adapted from the great Emonlib source.Connecting to Thingspeak makes it easy to plot the current and save the data being gathered continuously. Create an account and fill in the API key in the Arduino sketch above.
Looks very nice. I'm attempting to gather all the devices, but I'm running into problems finding it all. Is there a part list with more details/part numbers that I'm missing?
Ah, just saw the tindle. Ok!
Hi, Thanks for this project.
I have implemented your code to upload data on emoncms but I would like to know how to properly calibrate the voltage and current readings. I have tried to calibrate the value by trial and error but would like to know what formulas you used to find those values.
Thanks a lot for the positive comment really appreciated. I currently use Thingspeak for data upload and storage. One of my customers for the PCB is using his own server with MQTT. The whole scheme offers a lot of flexibility and choice in how you monitor the energy usage. With the OTA upgrade options for ESP8266 you can also change your mind after setting it up the first time.
Looks really good. I'm very interested in this project. I'd love to see more detail. Is all the data being stored on the device or on a separate server? Or is it just a live monitoring solution with no historic data? What are you presenting to a user, if you're running a web server on the esp8266?? Keep up the great work.
Sorry for the late reply. Data is being uploaded to thingspeak with 20s interval which is their per channel rate limit (more like 16seconds I think). Now that it is a paid service I am considering logging to local microSD and allowing extraction via a web interface/API.
