The new rev2 PCBs did arrive from OSH park. I hope the p-fet bug is fixed now. I am still waiting on some parts (the new p-fet LEDs in not red). When I do have all parts I will solder one and take some more pictures.
If you want to get your own ones, here you can order the PCBs: https://oshpark.com/shared_projects/LDcRWFo1
Please Share some photos if you built one
awesome !
Have you seen the new option for thinner PCBs in there? I think it makes sense for small boards.
yes I saw it. But did not used it because of the longer production time. But i will test it if this revision is working right.
The more people uses this, the faster the production time will be. But I know what you mean, I ordered mine two weeks ago and they are still "in the board house".
